There are two parts to this code, creating a vbs file that sits on the server (which moves the folders) and ti code that calls the vbs file.
The code will need to be modified to apply to your server:
D:\Cognos\TM1 Servers\planning\data\ is where the data directory is
D:\Cognos\TM1 Servers\planning\archive\ is where the profile folder will be archived to
VBS FILE:
dim filesys
userFolder = WScript.Arguments(0)
set filesys=CreateObject("Scripting.FileSystemObject")
If filesys.FolderExists("D:\Cognos\TM1 Servers\planning\data\"& userfolder) Then
filesys.CopyFolder "D:\Cognos\TM1 Servers\planning\data\"&userFolder, "D:\Cognos\TM1 Servers\planning\archive\"&userFolder
filesys.DeleteFolder("D:\Cognos\TM1 Servers\planning\data\"&userFolder)
End IfIn my case, I call the vbs file in the EPILOG of the 'remove user' process. The first parameter is where the VBS file sits on the server and pUser is a parameter of the 'remove user' process'. Just note that if any folders in the script path have a space in the name, then you will need to add speech marks, ie. cognos\"TM1 servers"\planning.
EPILOG of DeleteUser:
S_Run = 'cmd /c D:\Cognos\"TM1 Servers"\planning\Archive\ArchiveExpired.vbs ' | pUser;
ExecuteCommand(S_Run,0);Furthermore, to retrieve a list of profile folders without active accounts you can run this vb in a spreadsheet (you will need to log into the server first though):
Sub Ck()
Dim strStartPath As String
Dim servername As String
strStartPath = "\\servername\d$\cognose\tm1 servers\planning\data"
servername = "planning"
ListFolder strStartPath, servername
End Sub
Sub ListFolder(sFolderPath As String, servername As String)
Dim FS As New FileSystemObject
Dim FSfolder As Folder
Dim subfolder As Folder
Dim i As Integer
Dim j As Integer
Dim k As Integer
Dim l As Integer
Set FSfolder = FS.GetFolder(sFolderPath)
For Each subfolder In FSfolder.SubFolders
subfoldername = Right(subfolder, Len(subfolder) - Len(sFolderPath) - 1)
'DoEvents
'Add your own criteria here to determine whether a folder is a profile folder
If (Len(subfoldername) = 7 And UCase(Left(subfoldername, 1)) = "T") Then
i = i + 1
Cells(i, 1) = subfoldername
isFound = Application.Run("DIMIX", servername & ":}clients", subfoldername)
If isFound > 0 Then
j = j + 1
Cells(j, 2) = subfoldername
Else
k = k + 1
Cells(k, 3) = subfoldername
'You could archive the folder here if you wish
End If
End If
Next subfolder
Set FSfolder = Nothing
End SubI created a formula to generate the below code in the spreadsheet to be used in a bat file. In hindsight though, you could also have this step generate Col D at the same time as Col C. Place the bat file on the server though and let it run.
move d:\cognos\"tm1 servers"\planning\data\6482 d:\cognos\"tm1 servers"\planning\archive
move d:\cognos\"tm1 servers"\planning\data\2849 d:\cognos\"tm1 servers"\planning\archive
move d:\cognos\"tm1 servers"\planning\data\1605 d:\cognos\"tm1 servers"\planning\archive
