TM1 Architect, Cognos BI Security and Siteminder
type2sam
Version: 9.5.2
Post by type2sam »
All,
Running into an interesting issue at a customer site...
We have a 10.1.1 TM1 server running security mode 5...which delegates authentication to Cognos BI...which leverages Siteminder.
If I connect to this server with TM1 Web, I am appropriately challenged by a Siteminder web interface, then upon entry of the appropriate credentials, passed onto TM1Web and everything works as intended.
If I try to connect with Architect 10.1.1 on my desktop, I get the Siteminder web page, which quickly redirects to another page (the customer's intranet page) before credentials can be entered. Not what we want.
Strangely, if I attempt to use Architect 9.5.2 on my desktop, I get the siteminder web page but no instant redirect...I get the opportunity to provide credentials and log in (like TM1Web) and Architect works/behaves as I expect.
No changes were made to the tm1s.cfg file during this testing, this config file has been migrated from a 9.5.2 environment and there are no references to clientminimum version or max version.
Any thoughts?
qml
Excel Version: 2007 - 2016
Re: TM1 Architect, Cognos BI Security and Siteminder
Post by qml »
Just a thought - are your web.config settings the same? Especially the ExternalUrl parameter?
Kamil Arendt
type2sam
Version: 9.5.2
Post by type2sam »
Perhaps I am not following you...but if 10.1.1 TM1Web is working fine...and 9.5.2 Architect is working fine...why would I need to change web.config?
qml
Post by qml »
I have nothing in my defence except for the fact that it's Friday evening. Nothing to see here, move along... :oops:
Kamil Arendt
