Action Button issue
Rosanero4Ever
Version: 10.1.1
Action Button issue
Post by Rosanero4Ever »
I create a simple spreadsheet with an action button linked to a process.
This process has 3 parameters in input (please see the attached image)
With this setup, the process works well
After inserting the button I tested the functionalities immediately and they worked well.
So, I saved the spreadsheet.
After a day I opened the same file and I noticed that action button parameters was in an incorrect form (see the attached image please) and the action button doesn't work.
I have found this process setup. Obviously the process doesn't work
Does anybody can tell me the reason of this issue and how can i solve it, please?
Re: Action Button issue
This is a known issue/bug and I can't off the top of my head remember whether it was the version of excel you were using combined with TM1 version etc.
But to avoid stuff like this I tend to always save the books in Excel 97-2003 xls format as opposed to xlsx, try that and see if you have the same issue?
Edit - From what I remember it was an issue of using a version of Excel that wasn't fully compatible with your version of TM1 e.g. TM1 9.5.1 with Excel 2010... but I noticed that you are using TM1 10 so I might be thinking of a different issue altogether
Rosanero4Ever
Version: 10.1.1
Great!
I saved all my spreadsheet in XLS formato and now all work well!
Many thanks!!!
