Rule to write string from Consolidation to Leaf Element
PavoGa
Excel Version: 2013 PAW
Post by PavoGa »
TM1 How to do String rules to feed or populate leaf elements from a consolidation.
We have a control cube where we want to populate the level 1 consolidation with a string value and automatically have the underlying leaf elements populated with the string value of their respective parents.
In the example, I want the three CCs populated with "Same" for Apr, May & June.
Current rule:
FEEDSTRINGS;
['CtrlValue'] = S: IF(SUBST(DB('CtrlCube', !Region, 'CtrlValue'),1,4) @= 'Cost',
DB('CtrlCube', 'Region' | subst(DB('ctrlCube',!Region, !ctrlDim) 11,3) , 'CtrlValue'), CONTINUE);
I do not get any errors, just the leaf elements are not populated.
Ty
Cleveland, TN
Re: Rule to write string from Consolidation to Leaf Element
PavoGa wrote:TM1 How to do String rules to feed or populate leaf elements from a consolidation.
Current rule:
FEEDSTRINGS;
I have had a few beers tonight so I could be wrong but does your rule actually relate to the cubeview you've attached a picture of?...
Assuming from the image that "same_store" is the string element from your measures dimension you could go with:
['same_store']=S:
If ( Ellev ( 'ty_test', !ty_test ) > 0, STET, DB( 'Cube', Elpar ( 'ty_test', !ty_test, 1), !Period, 'same_store') );
However I would use an ATTRS rather than an Elpar so that you don't have to worry about moving hierarchies etc.
HTH
