TM1 Process/Action Button
vCmd = '"C:\Program Files (x86)\Microsoft Office\Office14\Excel.exe" "E:\Data\TM1\test\P & L Report.xls';
ExecuteCommand(vCmd, 0);
Private Const srvName As String = "tm1serv"
Private Const savPath As String = "E:\Data\TM1\test"
Private S1 As Excel.Worksheet, s2 As Excel.Worksheet
Private ret As Variant
Sub burst()
On Local Error GoTo ERR_burst
Dim ws As Excel.Worksheet
n = Run("SUBSIZ", srvName & ":SAP Dept", "Test")
Set S1 = Sheet1 'cookie cutter
For i = 2 To n '1 is the 1st one
'Debug.Print i, Run("SUBNM", srvName & ":SAP Dept", "Test", i, "Code+Desc")
sCopy Run("SUBNM", srvName & ":SAP Dept", "Test", i, "Code+Desc")
Next
'Exit Sub
emailMessage "P & L Reports", "Process Complete"
'savPath && always overwrite
Application.DisplayAlerts = False
Me.SaveAs Filename:= _
Me.Path & "\" & Left(Me.Name, Len(Me.Name) - 4) & "_Values.xls", FileFormat:=xlNormal _
, Password:="", WriteResPassword:="", ReadOnlyRecommended:=False, _
CreateBackup:=False, ConflictResolution:=xlLocalSessionChanges
Exit Sub
ERR_burst:
Debug.Print Err.Description
emailMessage "P & L Reports - Error", Err.Description
End Sub
Sub sCopy(elName As String)
S1.Copy , S1
Set s2 = ActiveSheet
s2.Range("vDept").Value = elName
s2.Name = Left(elName, 11)
Set S1 = s2 'duplicate fwd in series
End Sub
Sub TI_Connect()
ret = Run("N_CONNECT", srvName, "admin", "apple")
Debug.Print ret
End Sub
Sub TI_Disconnect()
ret = Run("N_DISCONNECT")
Debug.Print ret
End Sub
Private Sub Workbook_Open()
On Local Error GoTo ERR_Open
If Application.Calculation <> xlCalculationManual Then Application.Calculation = xlCalculationManual
If Application.CalculateBeforeSave <> False Then Application.CalculateBeforeSave = False
If InStr(1, Me.Name, "_Value", vbTextCompare) <> 0 Then Exit Sub
If openTextFile = 0 Then Exit Sub
TI_Connect
burst
TI_Disconnect
'Me.Close
With Application
.Wait Now + TimeSerial(0, 0, 3)
.Quit
End With
Exit Sub
ERR_Open:
Debug.Print Err.Number, Err.Description
Application.Quit
End Sub
Function openTextFile() As Byte
Dim S1 As String
Close #1 ' Close file.
Open Me.Path & "\reportConfig.txt" For Input As #1 ' Open file for input.
Input #1, S1 ' Read data into variable.
openTextFile = Val(S1)
End Function
'this will only work on the server, 9476 = Ok
Sub emailMessage(subject As String, body As String, Optional recipient As String = "tm1admin@myco.com.au")
Dim vCmd As String
vCmd = "cmd /c D:\sendmail\sendmail.exe -ini -to " & recipient & " -sub """ & subject & """ -body """ & body & ""
ret = Shell(vCmd, vbHide)
Debug.Print ret
End Sub
