Writing rule in sparsed cube
ioscat
OLAP Product: Contributor
Version: 9.5.2 10.1.1 10.2
Excel Version: 07+10+13
Post by ioscat »
Hello, community.
As far as i know it's not possible to put ATRRS or DB in left part of any rule.
['Company Name 001', DB(<...>,!Company Name, 'City')]=N:...
Let the test cube have just two not small dimensions - 'Company Name' and 'City'. Let in one city there are just only few companies, so we can build matrix of cities/companies (let it is named 'The Matrix' and it is sparsely filled by number '1').
If we need to calculate something for company we have to write partitioning IF rule:
[]=N: IF(DB('The Matrix', !COmpany Name, !City)=1,<...the rule...>,0);
Is there any other way write the rule?
Upd. one other way is to multiply by DB('The Matrix',...) that is 1 or 0
Re: Writing rule in sparsed cube
Just one quick pointer is that if it is going to be seriously sparse in the sense that most of your results will be derived from the "ELSE" part of your IF statement I would change it to be a STET instead of a 0 and then make sure people can't change it by implementing security:
[]=N: IF(DB('The Matrix', !COmpany Name, !City)=1,<...the rule...>,STET);
Duncan P
Version: 9.5.2 10.1 10.2
Excel Version: 2003 2007
Post by Duncan P »
Why?
Duncan P wrote:Why?
I am assuming this was directed towards my comment? If not then feel free to all ignore this comment otherwise:
Build 2 identical 2-d cubes with 2000 elements in d_test_dim (mixture of N and C) and 1 element in d_test_measures
Apply the following rules:
Cube A:
[]=N: 0;
Cube B:
[]=N: STET;
You will see a higher memory usage in Cube A than Cube B.
