Improve my feeder! :)
fleaster
Excel Version: XL2010
Post by fleaster »
I am currently constructing a rule for cost centre/account/product allocations. In a nutshell it is simply : amt input by user x product % allocation for the cost centre
Simple enough, but the complication comes because under the reporting methodology, the account mapping changes depending on the allocation. Hence we have a multi-layered GL account structure that looks something like this e.g.
+0916510000 (Base GL)
-0916510000-6A29670 (PreAllocation GL from user input)
-0916510000-6A29670-1639 (Allocation GL for calculation)
-0916510000-6A99999-1639 (Recovery Offset GL for calculation)
(the pre/allocation GLs will then map to other reporting lines depending on their extension)
['BIZ1 Calc Test'] = N:
# if account is an allocation string (rolls up to Expenses & >18 digits & without recovery extension & function extension matches RC) - then calculate product allocation
If( ELISANC('Account', DB('z_ctrl_measures','Account Type 05','PMF_Rollup'), !Account)=1 & Long(!Account)>18 & Subst(!Account,12,7)@<>'6A99999'
    & Subst(!Account,20,10)@=Attrs('ResponsibilityCentre',!ResponsibilityCentre,'Function') ,
           DB('Fin_GL',!Version,'BIZ1 Input',!SectionA,!SectionB,!SectionC,!Company,!Affiliate,!FunctionalCell,'9991',!ProductProcessor,!ResponsibilityCentre,Subst(!Account,1,10),!CurrencyCode,!Period,!BalanceType,!MeasureType)
            * DB('Fin_GLAllocation',!Version,'BIZ1 Input',!Product,!ProductProcessor,!ResponsibilityCentre,'No Account','GENX',!Period,'Proportion')
           , STET);
The corresponding feeder I have tried is:
# feed input to calc test - limit products using Allocation Products structure + extract first 10 digits of Account
['BIZ1 Input',Product:'9991']=>
     DB('Fin_GL',!Version,'BIZ1 Calc Test',!SectionA,!SectionB,!SectionC,!Company,!Affiliate,!FunctionalCell,'Allocation Products',!ProductProcessor,
     !ResponsibilityCentre,SUBST(!Account,1,10),!CurrencyCode,!Period,!BalanceType,!MeasureType);
...however it seems to work a bit slow... am wondering does anyone have any ideas how to feed this rule properly without using a conditional feeder? possibly an intermediary lookup cube...?
cheers! :)
Matt
ioscat
OLAP Product: Contributor
Version: 9.5.2 10.1.1 10.2
Excel Version: 07+10+13
Re: Improve my feeder! :)
Post by ioscat »
Have you checked your model for overfeeding?
It's simple technique with new clone cube and 1 rule IF(<..>=0,1,0)
fleaster
Post by fleaster »
thanks for the feedback :)
...i ended up going with the following as a feeder :
['BIZ1 Input',Product:'9991'] =>
DB('Fin_GL',!Version,'BIZ1 Calc Alloc',!SectionA,!SectionB,!SectionC,!Company,!Affiliate,!FunctionalCell,'Allocation Products',!ProductProcessor,!ResponsibilityCentre,
!Account | '-' | Attrs('ResponsibilityCentre',!ResponsibilityCentre,'Function') ,!CurrencyCode,!Period,!BalanceType,!MeasureType) ;
...it works, but seems to have a few niggling performance issues when calculating at top level :(
