TM1 server load failed - Persistent Feeder error
Posted: Mon Mar 25, 2013 12:29 am
Hi Experts,
I have an issue in loading the TM1 server after the scheduled chore to restart TM1 server at 3AM, because of the below error server load failed.
The error points out "Persistent Feeder" but I've chore that runs at 2AM to delete all Persistent Feeders before the server restart. Interestingly server gets loaded without any error if I manually kick start. This is happening only for last 2 weeks, the Group_Scorecard has in the system for longtime and no major changes has been done in the server side recently.
The only thing I suspect is a chore which updates the dim hierarchies at 1AM and in last 2 weeks it throws "circular reference" error will that affect the server load? If anybody come across this issue please throw some light.
TM1 Version: 9.5.1
Any inputs are welcome!! Thanks!
3832 [] INFO 2013-03-17 16:10:24.770 TM1.Cube Loading body for cube }ElementAttributes_Group_Scorecard
3832 [] ERROR 2013-03-17 16:10:24.770 TM1.Server ***** Persistent Feeder error *****
3832 [] ERROR 2013-03-17 16:10:24.770 TM1.Server Feeder file error/inconsistancy detected for cube "}ElementAttributes_Group_Scorecard" reason:
Have processed feeder files but this cube does not have a feeder file
3832 [] ERROR 2013-03-17 16:10:24.770 TM1.Server **********
3832 [] ERROR 2013-03-17 16:10:24.770 TM1.Server All persistent feeder files will be deleted and server will shut down
3832 [] ERROR 2013-03-17 16:10:24.770 TM1.Server Restart server to re-load database.
3832 [] ERROR 2013-03-17 16:10:25.005 TM1.Server Phase 1 of server load failedThe only thing I suspect is a chore which updates the dim hierarchies at 1AM and in last 2 weeks it throws "circular reference" error will that affect the server load? If anybody come across this issue please throw some light.
TM1 Version: 9.5.1
