Copying the Data from Cube B to Cube A
TM1ethusiast
- Version: 9.5.2
I have two cubes A and B within a same server but on two different instances,I want to move the forecast data in to B.What i know is we could use rules and DB reference to copy the data,but is any other way around?Thanks in Advance
rmackenzie
Re: Copying the Data from Cube B to Cube A
This sounds a bit similar to this question. Is it the same situation? If the cubes are in different instances then rules are not an option but you can transfer data between the two cubes via flat files, or replication - the former method being preferred.TM1ethusiast wrote:I have two cubes A and B within a same server but on two different instances,I want to move the forecast data in to B.What i know is we could use rules and DB reference to copy the data,but is any other way around?Thanks in Advance
Robin Mackenzie
TM1ethusiast
- Version: 9.5.2
Thanks,rmackenzie,Appreciate your help.
