Absolute Measure
- Version: 9.5.2
Absolute Measure
I have two measure in my measures dimension for Currency.Now there is requirement that i need to add third measure which should be absolute measure (always display positive value).Had it been Cognos i would have drag a data item and write abs(measure value) and there you go! Is any easy way to do it TM1.appreciate your help.Thanks
- OLAP Product: tm1
- Version: 10 2 2 - 2.0.5
Re: Absolute Measure
Just add abs(MeasureValue) to your rule and there you go!
Not forgetting your feeder(s)
- Version: 9.5.2
Thanks for your help.Currently i don't have any rules defined on the cube.Any other way around or i have to have write a rule?
- George Regateiro
- Version: 10.1.1
- Excel Version: 2007 SP3
That depends on how this data is used or updated. You could write a process that populates that measure with the same abs logic. But this would not be realtime. If your entry is only through templates where you could assign an action button this is pretty easy to do, but if you are entering through multiple touch points then you will have an issue with this method.TM1ethusiast wrote:Thanks for your help.Currently i don't have any rules defined on the cube.Any other way around or i have to have write a rule?
The rule is the safer method and should not impact performance (assuming properly structured static and working versions that are fed properly).
- Version: 9.5.2
Hi all,I have written a rule below it is say va_measures element doesn't exist ,where as va_measures is dimension name
Skipcheck;
['Absolute FR value']=N:['va_measures',abs('FR value')];
Feeders;
[abs('FR value')]=>['Absolute FR value'];
could you please tell me the correct syntax.Thanks
Skipcheck;
Feeders;
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
The function goes round the cell reference - not the other way round
and you probably don't need the dimension name - and if you did it would be
['Absolute FR value']=N: abs( ['FR value'] );
['va_measures':'Absolute FR value']=N: abs( ['va_measures':'FR value'] );
- Version: 9.5.2
Thanks Duncan.Appreciate it a lot.
- Version: 9.5.2
Hi All, I have added below rule to the cube and it is showing no errors,but the data is incorrect for absolute FR value ,as when i check through one element the value for FR value is -19,374 where as absolute value is 347,27,796.Where my intention is to show -19,374 as 19,374 where iam going wrong ,Please help.
Skipcheck;
['Absolute FR value']=N:abs(['FR value']);
Feeders;
['FR value']=>['Absolute FR value'];
Skipcheck;
Feeders;
TM1ethusiast wrote:Hi All, I have added below rule to the cube and it is showing no errors,but the data is incorrect for absolute FR value ,as when i check through one element the value for FR value is -19,374 where as absolute value is 347,27,796.Where my intention is to show -19,374 as 19,374 where iam going wrong ,Please help.
Skipcheck;
Feeders;
Are you by any chance viewing it at a consolidated level?
FR Value: 10,000 + (7,000) + (6,000) = (3,000)
Absolute Value: 10,000 + 7,000 + 6,000 = 23,000
If that is the case, you need to consider whether you want/need the "=N:" or not.
- Version: 9.5.2
Thanks Declanr,I am looking at leaf level,for example for the leaf element A the FR value is -6,742 but the Absolute FR value is 35,181,Strangely enough this is happening with negative values only where as positive values are somewhat closer.
You are positive:TM1ethusiast wrote:Thanks Declanr,I am looking at leaf level,for example for the leaf element A the FR value is -6,742 but the Absolute FR value is 35,181,Strangely enough this is happening with negative values only where as positive values are somewhat closer.
A/ That EVERY dimension is at the leaf level?
B/ The only rules in your cube are what you have posted above in this topic?
If both of the above statements are true, can you post a screenshot of what you are seeing.
- Version: 9.5.2
Thanks Declanr,You are spot on the dimensions had all levels selected,what i did is created a sample test cube with two leaf level elements and wrote the same rule and the did worked right,so ,i guess it has to do with the levels of data.I will do further testing tomorrow.Appreciate your help.
- Version: 9.5.2
Hi Declanr, Could you please tell me if i need to show the Absolute value at Consolidation level,I just need to remove the :N and add :C or just removing :N will do.Appreciate your help.Thanks
"=" Applies to both N-Level and C-level cellsTM1ethusiast wrote:Hi Declanr, Could you please tell me if i need to show the Absolute value at Consolidation level,I just need to remove the :N and add :C or just removing :N will do.Appreciate your help.Thanks
"=N:" Applies to only N-Level cells, C-Level cells will consolidate as standard unless otherwise defined
"=C:" Applies only to C-Level cells, N-Level cells will be "open for entry" unless otherwise defined
"=S:" Applies to string cells (not relevant here)
TM1ethusiast,
I am not really sure what you are trying to do as your end result but in your question above you have stated your options, the best course of action would be to try each one out and then see if the results are what you would like to see. If it looks as you want it to then you have the right option. Even if it is the last one you check; all in all it should take less than 10 minutes.
I personally can't think of many examples where you would need the C-Level absolute value to be anything other than the naturally consolidated total of it's N-level constituents. However if for some reason you do need it to do that in its own right then just remove the qualifier and stick with "=".
The above can be found in the rules guide under the "Components of a Rule" section. The rules guide isn't always perfect but it usually explains basic introductory concepts well enough if you mix in a little bit of trial and error testing. Failing that it would be good to try and get on an instructor-led training course if you find it easier to learn through tuition. IBM obviously have their own offerings; as do a number of business partners.
HTH
