I've got a problem - i'm running my TI process by TM1runTI.exe I have to automatize this process - i've got a filter on a measure and after completion of the process i need publish package with another data in a filter.
But after publishing when i want to run process i got the errror message: Calling process aborted. In my log file in TM1 i see: "Package or report is not accessible."
But when i run process by hand in Architect everything is fine. What is more when i open my process in Architect and click 'close' i've got message: 'do you want to save the process?' (but i didn't change there anything) and EVERYTHING IS FINE (I can normally run my process by TM1runTI.exe)
So I think that after publishing it doesn't see package, and should be 'refresh' - may be You know if i can do it outside of an architect? Or maybe i'm wrong.
I thought, it is because of i was publishing package by BmtScriptPlayer.exe, but it's the same when i do it by Framework Manger.
Michael
calling process aborted TM1runTI.exe
- OLAP Product: none
Re: calling process aborted TM1runTI.exe
OK, i solved it - You can't publish package with checked option 'delete previous model versions'
But problem now is another - it seems like TM1 process doesn't see package when it is running outside of Architect. I have a filter on measure in package. And process doesn't see that the filter is changed when i run it putside of Architect. What is more when I'm publishing an empty package, my process still can be run without error messages (i still run it by TM1runTI.exe).
Do You know where a problem can be? Can I do something with it?
