To see chore scheduled timing
Posted: Thu Mar 14, 2013 4:22 am
by Rams
Hi TM1 Geeks,
This must be a silly question to ask
, but I'm looking for the best way to see the chore scheduled timing other than the below methods. I heard TM 1 web will do but we are not using at all.
1. First strike, deactivate the chore and see the scheduled timing - which is registered in a log file <don’t want to leave a footprint>
2. Secondly, I can just a click on the chore, shows the process involved in property window and then double click on the process will do, but this will not work if there are more than one process involved in a particular chore as a sequence.
Any inputs are welcome,
Ram
Re: To see chore scheduled timing
Posted: Thu Mar 14, 2013 4:42 am
by failurehappening
If you have access to the file system you can look at the .cho object in notepad. It will look like this:
535,Daily Backup 9pm
530,20130118130102
531,001000000
532,1
13,16
6,"Sys.Serv.Backup"
560,0
533,1
1405,0
The 3rd line down, after the comma, indicates the date and time (in GMT) that is configured in the chore window. Here we have 530,20130118130102 which shows the backup was scheduled to run from the 18th January 2013 at 13:01.02 GMT, which is 9PM in Perth.
The 4th line down, after the comma, indicates the frequency. Here we have 531,001000000 which shows it is set to run every day. The break up for that is the first 3 digits is days, then 2 hours, 2 minutes, 2 seconds.
Posted: Thu Mar 14, 2013 4:52 am
by Rams
That's Kewl stuff to note....thanks & its very helpful by the way what if the people who are using the client tool alone (perspective)...just curious to know
I hope the best practice is to give the "CHORE_NAME (Weekly/Daily <day> <time> <am/pm>)"
Posted: Thu Mar 14, 2013 5:10 am
by Rams
to add up, I was wondering how could we know whether its active or inactive by just looking into .cho file, Finally found
533, 1- Active & 0 - Inactive chore.
Thanks "failurehappening"
Posted: Sun Mar 17, 2013 10:32 pm
by Gareth Soo
Hi Ram, give my chore scheduler a go. I have already mapped it to read the server chore files and display them in a spreadsheet:
http://www.tm1forum.com/viewtopic.php?f=21&t=8587
Posted: Tue Mar 19, 2013 3:30 am
by Rams
Hi Gareth - Thanks for the spreadsheet!!!
I'm getting an error while the macro trying to open the RUX files. I've connected as client machine, so path should be something like below, I guess its not the problem with path.
\\servername\d$\sharefolder\tm1servername\Data
"Set TextStream = FSO.OpenTextFile(directory & f1.Name, 1, False, -2)"
Posted: Wed Mar 20, 2013 2:15 am
by Gareth Soo
Try adding a \ to the end of the path
Posted: Thu Mar 21, 2013 6:14 am
by Rams
Kudos!!!, it works and very handy one for quick analysis.... Thanks Gareth!!!
