I'm getting an error on my Cognos Express Installation when i am trying to execute a chore. When i execute the process (that's in the chore) stand-alone, the process works.
Contents of the error file:
1732 [e5] INFO 2013-03-13 14:27:52.138 TM1.Chore Chore ImportCubeBudget executed by user Cognos Express\Cognos Express Administrator_CAMID(_CognosExpress_administrator_)
1732 [e5] INFO 2013-03-13 14:27:52.138 TM1.Process Process import_ Budget vs Realisation Sales Cube1 executed by chore ImportCubeBudget
1732 [e5] ERROR 2013-03-13 14:27:52.153 TM1.Process Process "import_ Budget vs Realisation Sales Cube1": : Execution was aborted. Error file: <TM1ProcessError_20130313142752_import_ Budget vs Realisation Sales Cube1.log>
1732 [e5] INFO 2013-03-13 14:27:52.153 TM1.Chore Chore ImportCubeBudget finished executing
1732 [e5] INFO 2013-03-13 14:37:40.157 TM1.Process Process "_FileAccessProcess" executed by user "Cognos Express\Cognos Express Administrator_CAMID(_CognosExpress_administrator_)"
1732 [e5] ERROR 2013-03-13 14:37:40.157 TM1.Process Process "_FileAccessProcess": : Execution was aborted. Error file: <TM1ProcessError_20130313143740__FileAccessProcess.log>
1732 [e5] INFO 2013-03-13 14:37:40.251 TM1.Process Process "import_ Budget vs Realisation Sales Cube1" executed by user "Cognos Express\Cognos Express Administrator_CAMID(_CognosExpress_administrator_)"
1732 [e5] INFO 2013-03-13 14:37:40.298 TM1.Process Process "import_ Budget vs Realisation Sales Cube1": finished executing normally, elapsed time 0.05 seconds
And the contents of the fileaccessprocess.log file.Error: Prolog procedure line (0): Unable to open data source "d:/program files (x86)/ibm/cognos express/xcelerator/custom/tm1data/cxmd\import_ Budget vs Realisation Sales Cube1.blb".
Could someone help out with this? I allready tried to re-create the process and the chore. The file that is mentioned in the error does not exist, a file with the same name but with a ".pro" extension exists.Error: Prolog procedure line (4): ProcessError()
Additional note: i 've been using Performance Modeler to build this model.
