Greetings everyone,
I am new to TM1 and have a very simple question (hopefully). I'm trying to copy data between two views in the same cube using a TI process. I would like to map one dimension to one of its attributes. Is this possible? I tried doing this but get the error that "Dimensionname is not allowed". My syntax is:
if (VALUE_IS_STRING=1,
CellPutS(SVALUE,Cube,vVersion,ATTRS('Account',Account,'NewAccount'),vProduct,vMeasure),
CellPutN(NVALUE, Cube, vVersion,ATTRS('Account',Account,'NewAccount'),vProduct,vMeasure));
Thanks for any help!
Using ATTRS in a TI process
Re: Using ATTRS in a TI process
Your syntax is not valid because your conditions are not inside an IF..ENDIF block.
rmackenzie
Although most people use the IF..ENDIF block, the syntax is actually OK. Try this test code:tomok wrote:Your syntax is not valid because your conditions are not inside an IF..ENDIF block.
nTest = 0;
IF ( nTest = 1,
AsciiOutput ( 'temp.txt', 'nTest is 1' ),
AsciiOutput ( 'temp.txt', 'nTest is not 1' ));Code: Select all
nTest = 0;
IF ( nTest = 1 );
AsciiOutput ( 'temp.txt', 'nTest is 1' );
ELSE;
ENDIF;I would check that the values for Cube, vVersion, Account, vProduct and vMeasure are all genuine elements in their respective dimensions - and that Cube is really the name of the cube. Then check that the values for NewAccount are also element names. Use an AsciiOutput to do the debugging:destry2 wrote:I'm trying to copy data between two views in the same cube using a TI process. I would like to map one dimension to one of its attributes. Is this possible? I tried doing this but get the error that "Dimensionname is not allowed". My syntax is:
sNewAccount = ATTRS('Account',Account,'NewAccount');
AsciiOutput ( 'temp.txt', Cube, vVersion, Account, sNewAccount, vProduct, vMeasure );
IF (VALUE_IS_STRING=1 );
CellPutS(SVALUE,Cube,vVersion,sNewAccount,vProduct,vMeasure);
ELSE;
CellPutN(NVALUE, Cube, vVersion,sNewAccount,vProduct,vMeasure);
ENDIF;Robin Mackenzie
destry2
Thanks for everyone's insight. Was able to get it to work - I was not referencing my variable correctly. Thanks
