Xcelerator copy and paste as values
Posted: Sat Mar 09, 2013 4:48 pm
by Don McC
I have a large xcelerator/excel report, 17 tabs in one workbook.
To disitribute the data from the xcelerator report, I currently have to copy and paste the data from the original spreadsheet into another spreadsheet as values.
So I run the report once, copy and paste all of the values and then save the spreadsheet.
Change one parameter, and then start all over again.
Can anyone point me in a direction re how I can automate this process, run the report and then click a buttom which will automate the movement of data from the original spreadsheet to a new spreadsheet. I also want to save the formatting from the original spreadsheet.
I want to make sure I start in a direction that has worked for others in the past.
thanks
Re: Xcelerator copy and paste as values
Posted: Sat Mar 09, 2013 9:05 pm
by tomok
Posted: Sun Mar 10, 2013 3:39 pm
You haven't been very clear as to what exactly the "parameter" is that is being changed but if it is a dimension element and you can cycle through a subset then the built-in "print report" function in the TM1 and Xcelerator add-ins is probably all you need. Are you aware of this feature?
Posted: Mon Mar 11, 2013 7:48 pm
by Don McC
The parameters are office locations, the 17 tab xcelerator report needs to be run once for each of 15 locations.
I will look at the print report function, but it sounds like it will print rather than create an electronic xls version of the report.
Posted: Mon Mar 11, 2013 8:22 pm
Don McC wrote:The parameters are office locations, the 17 tab xcelerator report needs to be run once for each of 15 locations.
Well that's where you would be wrong. :lol:
