DimElCompAdd Not adding anything :(
Posted: Fri Mar 08, 2013 5:56 pm
Hey all,
Starting Learning TM1 about a month ago, so at the risk of this being something incredibly asinine, here is the issue I have run into:
I am writing a process to either replace or amend a Dimension (user choice) using the input from a CSV. The CSV has 5 columns but here we are only dealing with 3. The first which is the element name. 3rd - EntityID, 4-EntityParentID. However the Dim hierarchy is supposed to be built on the 3rd and 4th Column IDs. So I have added these as Attributes. With each element's EntityID set to an Alias.
And Each element's EntityParentID set to a string Attribute.
The 1st Column the element's name, though all numbers I have also set to string for the purposes of making it easier to manage. (Less NTS calls).
On the Surface everything runs and checks out fine. ASCII outs are telling me exactly what I would hope to see. However once I get to the last step and the process completes successfully. I find I am left with no hierarchies at all. Just a single consolidated Orphans element and the relevant Level - 0's from the CSV and no parent/child relationships.
CSV Preview:
BUSINESS_UNIT DESCRIPTION EntityID ParentEntityID
527463 PB OTHER 1656392 1879149
418830 ASIA SOLUTION 1349775 1656392
425008 PB SPAIN - IC(JPMCB) 1355878 1656392
425009 PB SPAIN - IC(JPM SV) 1355879 1656392
423112 PB ADMIN - LATAM BRAZIL 1353982 1656392
PROLOG
METADATA
DATA
EPILOGE
Anyhow help/input/critiques all welcome.
-Thanks in advance!
CSV Preview:
PROLOG
####################PROLOG #####################
#Dimension Declaration
sDimName='BU';
#If Wipe Dim was Yes Vaporizes Dimension
IF (pDeleteAll@='YES'); DimensionDeleteAllElements(sDimName); ENDIF;
#Deletes all Elements Higher than Level 0
#If User Answered Yes to pReplace prompt
IF(pReplace@='Yes');
iIndex=DIMSIZ (sDimName);
WHILE(iIndex>=1);
sElement=DIMNM ( sDimName, iIndex );
IF ( DTYPE ( sDimName, sElement )@='C' % ELLEV ( sDimName, sElement )<>0);
DimensionElementDelete(sDimName, sElement);
ENDIF;
iIndex=iIndex-1;
END;
ENDIF;
#If Orpahns doesn't exist create it.
IF( DIMIX ( sDimName, 'Orphans') =0);
DimensionElementInsert ( sDimName, '', 'Orphans','C');
ENDIF;
#Create our 2 Attributes
AttrInsert(sDimName, '', 'EntityID', 'A');
AttrInsert(sDimName, '', 'ParentEntityID', 'S');Code: Select all
##################META-DATA#######################
sCurrentElem=vBUSINESS_UNIT;
IF( DIMIX( sDimName, sCurrentElem) = 0 );
# the new element is unique, let's add it
DimensionElementInsert( sDimName, '', sCurrentElem, 'N');
#Assign it Attributes 'EntityID (Alias)' & 'ParentEntityID(String)'
AttrPutS ( vEntityID, sDimName, sCurrentElem, 'EntityID');
AttrPutS ( vParentEntityID, sDimName, sCurrentElem, 'ParentEntityID');
Else;
#It Exists, findout where: principal or Alias:
sPrincipalNm = DimensionElementPrincipalName( sDimName, vEntityID );
IF( sCurrentElem @= sPrincipalNm );
# the new element matches the name of an already exusting element so we can't add it
ItemReject( sCurrentElem | ' matches a pre-existing element principal name');
Else;
# the new element matches the alias of an already exusting element so we can't add it
ItemReject( sCurrentElem | ' matches an alias value of element ' | sPrincipalNm);
EndIF;
EndIF;
################ DATA ########################
#Set sTarPar to the Element name of the Current Element's ParentID
sTarPar=DimensionElementPrincipalName( sDimName, vParentEntityID );
#If the current Elem's PARENT exists in the Dimension:
IF( DIMIX( sDimName, sTarPar ) <>0 );
#Add the current Elem to the Target Parent
DimensionElementComponentAdd ( sDimName, sTarPar, sCurrentElem, 1);
ELSE;
#Add the Element to Orphans
DimensionElementComponentAdd ( sDimName, 'Orphans', sCurrentElem, 1);
ENDIF;
DimensionSortOrder(sDimName, 'ByName', 'Descending',
'ByHierarchy' , 'Descending');-Thanks in advance!
