TM1 Object Auditor and Chore Schedule
Gareth Soo
Version: 9.52
Excel Version: 07
Post by Gareth Soo »
Hi all, this is a follow up post about the TM1 auditor that I put together earlier. It identifies the relationships between cubes, dimension, processes and rules to help identify impacted and redundent objects as well as document your server.
I have added a front-end for multiple servers and integrated a chore scheduler to identify when they run and their parameters.
It takes about 5-10mins to run each of our servers, results may vary but let me know if anyone has any issues running it.
https://www.dropbox.com/s/2zybi4gf9ciu2 ... audit.xlsm
ioscat
OLAP Product: Contributor
Version: 9.5.2 10.1.1 10.2
Excel Version: 07+10+13
Re: TM1 Object Auditor and Chore Schedule
Post by ioscat »
is it possible to connect it to server that is not deployed in contributor?
Gareth Soo
Version: 9.52
Excel Version: 07
I developed it for our TM1 enterprise system so i'm not sure if it works with contributor sorry. If it has a data directory with cub, dim, rux and pro files then it should work though.
ioscat
Post by ioscat »
yep, we have the data folder, but we didn't find way to make it work. could you please provide any instruction steps?
Gareth Soo
Version: 9.52
Excel Version: 07
Did you receive a VB error when you click 'Run'? You might be prompted to enable macros when you open the worksheet
Try these 5 steps:
1 - Save and open the worksheet in a location that has access to your server data directory
2 - Type in the server name as seen on server explorer in Column B (replace planning sample as it is an example)
3 - Type in the directory of the data folder in Column C including the network address if applicable and also include a \ at the end as VB gets confused otherwise
4 - Tick the audit reports you want to create and press 'Run'
5 - Spend 10 minutes to make a coffee and marvel at the report on your return
Let me know what error you receive if it still doesn't work
gdbanks
Post by gdbanks »
Hi Gareth,
I am getting the below error on the dimension and chore steps. But, the errors are random in that we only get them on some of the servers but not all.
Dimension:
Run time error 9: subscript out of range
strDimArray(j, i + 1) = dimension
Chores:
If StrCubesArray(i, 3, j) = "" Then
Gareth Soo
Version: 9.52
Excel Version: 07
It could be that you have lots of cubes or cubes with lots of dimenisons. I've upped the limits so give the new version ago:
jcr55
Version: 9.5.2 FP2
Excel Version: Excel 2007
Post by jcr55 »
I would like to try this out, but our web security blocks access to the dropbox site.
Can you email me the .xlsm file?
My email address is
Jeff.Rice@Genworth.com
Thanks in advance.
Jeff Rice
TM1 Administrator
Genworth Financial
cramejia_09
OLAP Product: IBM COGNOS TM1
Version: 9.4
Post by cramejia_09 »
Hi Gareth, the file is no longer available. pls help
Are you aware of Pulse for TM1? It has very good features for model audit and traceability of what impacts what in a TM1 model.
Usual disclaimers and admission of being associated with the product.
