Activeform rebuild vba loop not calculating
risk
Version: 9.5.2 FP3
Excel Version: 2010 and 2013 32bit
Post by risk »
My first post here and I'm pretty new to tm1 (6 months). I have a question regarding looping through activeforms with vba and rebuilding them. I'm having trouble getting the activeform to complete the rebuild prior to going to the next sheet resulting in activeforms that have not been rebuilt.
Below is my code which calcs an activeform and determines a unique list of customers, then goes into bulk reporting mode and creates many activeforms (by coping a template) for each of the customers. I've marked out the area of the code where the activeform rebuild should take place, but sometimes the code moves on to the next sheet without completing the activeform rebuild.
Sub FindCustomers()
Dim myRange         As Range
Dim intCust         As Long
Dim iReply          As Integer
Dim myCell          As Range
Dim Customers       As Range
Dim LastRow         As Long
Dim TotalRow        As Long
Dim TotalCol        As Long
Dim shtName         As String
Application.EnableEvents = False
With Sheet3
    .Activate
    .Application.Run "TM1Refresh"
    Set myRange = Sheet3.[TM1RPTDATARNG3]
    myRange.RemoveDuplicates Columns:=2, Header:=xlNo
    LastRow = .Cells.Find(What:="*", After:=Range("A1"), LookIn:=xlFormulas, LookAt:=xlPart, SearchOrder:=xlByRows, SearchDirection:=xlPrevious, MatchCase:=False, SearchFormat:=False).Row
    TotalRow = .Rows.Count
    TotalCol = .Columns.Count
    .Range(.Cells(LastRow + 1, 1), .Cells(TotalRow, TotalCol)).Delete
    intCust = myRange.Rows.Count
End With
With Sheet2
    .Activate
    .Range("A13", .Range("A13").End(xlDown)).Clear
    Set Customers = .Range("A13").Resize(intCust, 1)
    Customers = myRange.Columns(2).Value
End With
iReply = MsgBox("Would you like to run the report for each of these customers?" _
        & vbCrLf _
        & vbCrLf & "Warning, this could take a significant amount of time depending on how many customers and how many rebates!", vbYesNo, "Bulk Reporting Option")
        'begin bulk reporting
        If iReply = vbYes Then
            Sheet1.Range("C13:C16") = Sheet2.Range("B1:B4").Value
            For Each myCell In Customers.Cells
                Sheets("Report").Copy After:=Worksheets(Worksheets.Count)
                With ActiveSheet
                    .[C17] = myCell.Value
                    shtName = Run("DBRW", [server] & ":}ElementAttributes_Customer_Plan", myCell.Value, "RelatedCustomer")
                        If shtName = "Total Plan Customers" Then shtName = "All Other Customers"
                        If Len(shtName) > 30 Then shtName = Left(shtName, 30)
                    .Name = shtName
'****************** Issue here!  I've tried various calc methods and timers, but to no avail ************************************
                    .Application.Run "TM1RebuildCurrentSheet"
                    '.Application.Wait Now + TimeValue("00:00:01")
                    '.Application.Run "TM1Refresh"
                    'Call Application.Run("DoTM1Refresh", True)
                    'Call Application.Run("DoTM1Refresh", False)
                End With
            Next
        End If
Sheets("Report").[C13].Formula = "=SUBNM(server&"":Company"","""", ""1100"",""Description"")"
Sheets("Report").[C14].Formula = "=SUBNM(Server&"":Business_Segment"",""Default"",""A4"",""Description"")"
Sheets("Report").[C15].Formula = "=SUBNM(Server&"":Version"","""",""Current Forecast"")"
Sheets("Report").[C16].Formula = "=SUBNM(Server&"":Period"","""",""FY""&DBRA(Server&"":VERSION"",C15,""Year 1""))"
Sheets("Report").[C17].Formula = "=SUBNM(Server&"":Customer_Plan"","""",""Some Customer Name"",""Description"")"
End Sub
I've not found a complete list of VBA calc commands and was wondering if my assumptions below are correct:
Application.Run "TM1RebuildCurrentSheet"       'activeform sheet rebuild "Alt & F9"
Application.Run "TM1Refresh"                          'activeform sheet rebuild "Alt & F9"
Application.Run("DoTM1Refresh", True)            'activeform sheet rebuild "Alt & F9" with screen updating = true
Application.Run("DoTM1Refresh", False)           'activeform sheet rebuild "Alt & F9" with screen updating = false
Application.Calculate                                       'workbook calculate "F9"
Application.Run "TM1RECALC"                          'workbook calculate "F9"
Application.Run "TM1RECALC1"                        'worksheet calculate "Shift & F9"
Application.CalculateFullRebuild                        'rebuild workbook "Ctrl & Alt & F9"
And finally does anyone else use this method to work in autocalc mode?
Sheet1.EnableCalculation = True
Sheet1.EnableCalculation = False
Thanks for the help and I look forward to sharing some of my other vba solutions with the group.
-Kevin
Tm1 Version: 9.5.2
Excel Version: 14 x86
