Subset content doesn't change on TM1WEB
Tetsuo331
OLAP Product: Product
Version: Version
Excel Version: Version
Post by Tetsuo331 »
Hello everyone,
I am experiencing some trouble on a sheet on TM1WEB.
What I do is that I click a button that updates a dimension subset depending on selections maid by the user on the same sheet. Then I open the subset generated using a SUBNM function and pick an element to show its relative data...
The first time I click the button, everything works fine: I open the subset, I choose an element and I can visualize the data.
Then without closing the sheet, I change the selections and click the button a second time. It runs successfully and the subset is regenerated. I checked that on Architect. But when I click the SUBNM cell on the sheet I still see the first subset. :?
- The problem doesn't happen on Perspectives.
- The problem doesn't happen if I don't choose an element on the subset (i.e. if I just open the subset and close it back).
Any ideas?
Omar
Tetsuo331
Version: Version
Re: Subset content doesn't change on TM1WEB
Post by Tetsuo331 »
No Answers? :?: :(
Tetsuo331 wrote:No Answers? :?: :(
Do a search for "SUBNM+TM1Web" you will find this has been discussed many times before.
