Issue with Activ Form TM1RPTROW
Stéphane
Version: 9.5.2 FP1
Post by Stéphane »
Here is my issue :
I generate a simple Activ Form with Perspectives, the TM1RPTROW is used that way :
=TM1RPTROW($B$9;"tm1serv:analytique";"";'{AR}01'!$B$23;"Lib_fr";0)
'{AR}01' is an hidden sheet created by tm1, at $B$23 I find the value i originally set with my activ form : Direction Services Supports
in excel i see :
+ Direction Services Supports *my measure number*
which is fine to me
If in '{AR}01' i change the value of $B$23 (for example to Services centraux which is a son of Direction Services Supports) and i recalculate the activ form nothing change : my AF still
i still get
but expected
+ Services centraux *my measure number*
Can anyone tell me what I miss ?
(I'm 9.5.2 FP2)
Thank you very much
Re: Issue with Activ Form TM1RPTROW
To recalculate the active form including change of the rowset the active form must be rebuilt. You do this by using Alt + F9 keys or the "Rebuild" button or by calling the VBA function TM1REFRESH.
For a change such as the one you are talking about it is much better not to use the hidden {AR}01 worksheet and instead use the MDX argument of the TM1RPTROW formula to pass in the member or member expression that you want on the rows.
Stéphane
Version: 9.5.2 FP1
Post by Stéphane »
Yes it works !
Thank you very much
