Im trying to create an export from a cube view that should populate Cognos Controller Staging tables. I would like the users to do a select and click from excel and then use that excel in Tm1Web (that is then integrated into cognos 10 BI). The key points for the users are:
1. Create selections and multiple selections from existing dimensions, For instance multiple period values
2. Click a button that will run a TI-process that populates staging tables.
So my questions are:
Is this possible using active forms or similiar?
How should the view be created when users select multiple elements?
Am I on the wrong track here? I'm open for more creative ideas
Thanks in advance.
/Peter
