Need to Create TI process to delete the subsets
devathadeepak
OLAP Product: TM1 10.2.2 Cognos Planning10
Version: TM1 10.2.2 Cognos Planning10
Post by devathadeepak »
Hi Team,
I have 40-50 dimensions where each has 3-4 system generated Subsets , when i say system generated these are create by MDX statments in the processes.
Can you share the code to delete the subsets of all dimensions which are created with Prefix as 'SYS'.
Deepak
ioscat
OLAP Product: Contributor
Version: 9.5.2 10.1.1 10.2
Excel Version: 07+10+13
Re: Need to Create TI process to delete the subsets
Post by ioscat »
is possible to somehow call TM1DimensionSubsets?
Post by David Usherwood »
There's no direct TI command - but public subsets sit in the server directory in folders named <dimension>}subs . Write a TI to read the filesystem (remember the 'base' directory for TI is the server directory) using WildCardFileSearch. Once you've found the subset use SubsetDestroy. Word of warning - this will fail if the subset is part of a view, and they often will be.
If you have already looked at the bedrock code library how could you have failed to notice that it includes processes to perform exactly this function for views and subsets?
