Default view getting deleted post update of the dimension
Posted: Mon Jan 21, 2013 6:09 am
by devathadeepak
Hi Team,
We update dimensions with datasource option... ODBC link which connects to DB.
Issue: Every time i update my dimension the default subset gets deleted which is creating problem to open the report in Cognos BI.(Query studio reports).
Process Sequence :
Dimension Name : Account.
Process 1 : Deletes parent child relationship.
Process 2 : Update Hierarchy 1
Process 3 : Update Hierarchy 2
Process 4 : All leaf level elements.
Let me know the fix for the same.
Re: Default view getting deleted post update of the dimensio
Posted: Mon Jan 21, 2013 6:44 am
by ioscat
why not to build new hierarchy in next process? maybe it is possible to build default subset in the same process (prolog tab), but i'm not sure
Posted: Mon Jan 21, 2013 8:08 am
devathadeepak wrote:Hi Team,
Process Sequence :
I think you must be doing more than "delete parent child relationship". If you are
unwinding a dimension then static subsets will be preserved. On the other hand if you are deleting then recreating elements over multiple processes then loss of static subset members is expected. Check your code in process 1, if it contains DimensionDeleteAllElements or DimensionElementDelete then this is your reason. To preserve the static subsets including default then change process 1 to pure unwind (look at Bedrock code) then you could add a process 5 to tidy up if necessary by removing any orphan C elements and moving any orphan N elements to an "undefined parent" bucket.
Posted: Mon Jan 21, 2013 8:46 am
by devathadeepak
You are right ... i have the first process to delete the consolidated elements as below.
sDim='Account';
vDim_Cnt = DIMSIZ (sDim);
WHILE (vDim_Cnt >=1 );
Element = DIMNM ( sDim, vDim_Cnt);
IF ( DTYPE ( sDim,Element) @<> 'N');
DimensionElementDelete(sDim, Element);
vDim_Cnt = vDim_Cnt -1;
ELSE;
ENDIF;
END;
Currently the dimension is getting created with no elements in default subset.......is their any way to safegurd the default subset after dimension is updated.
Posted: Mon Jan 21, 2013 9:12 am
by devathadeepak
We have same code in bedrock too..
### Go through dimension and delete all C elements ###
nElementCount = DimSiz( pDimension );
nElementIndex = 1;
While( nElementIndex <= nElementCount );
sElement = DimNm( pDimension, nElementIndex );
sElType = DType( pDimension, sElement );
If( sElType @= 'C' );
If( pDebug >= 1 );
AsciiOutput( sDebugFile, 'Element: ' | sElement | ' will be deleted' );
EndIf;
If( pDebug <= 1 );
DimensionElementDelete( pDimension, sElement );
nElementCount = nElementCount - 1;
nElementIndex = nElementIndex - 1;
EndIf;
EndIf;
nElementIndex = nElementIndex + 1;
End;
Posted: Mon Jan 21, 2013 9:33 am
devathadeepak wrote:Currently the dimension is getting created with no elements in default subset.......is their any way to safegurd the default subset after dimension is updated.
Not to labour the point but you seem a bit slow on the uptake. Yes there is a way to prevent loss of subset members
don't delete the members from the dimension to start with! Maybe you misunderstand what is meant by "
UNWIND" which is to break all parent/child relationships (that is change the definition of the consolidated members) but without deleting any members.
Your bedrock code would seem to be from Bedrock.Dim.AllConsols.Delete. It is much faster to simply delete all consols and rebuild as unwinding requires recoursing through all children of each consolidation at all levels. Sometimes from a processing time perspective it is better to rebuild dimensions like this (and then rebuild all static subsets also). But I think what you need in this case is Bedrock.Dim.Unwind then (at the risk of repeating myself again) you won't have the problem you describe.
Posted: Mon Jan 21, 2013 10:37 am
by devathadeepak
Sorry for the confusion..
Process 1 : Delete the consolidated elements
In process 1 we are deleting all the consolidated elements , as you have explained we are not breaking the parent child relationship.
Process 1 :
sDim='Account';
ELSE;
ENDIF;
END;
Other processes are just update the hierarchy.
I have tried with both options in Process 1- unwind the hierarchy and delete the consolidated elements. However the Default subset is blank.
