Creating the Language Feed Files for Each TM1 Server
rinkugarg072
Version: Cognos TM1 10.1.0
Post by rinkugarg072 »
I want to access TM1 data from cognos BI servers so as suggested by vendor I am following the below link
http://pic.dhe.ibm.com/infocenter/cbi/v ... gfeed.html
I need to configure tm1_en.properties file so can you help me what value should i put in rootfeed_title_1 and rootfeed_summary_1 properties
The file path is c10_location\configuration\icd\contributions\contrib\tm1_en.properties.
rootfeed_title_1
rootfeed_summary_1
Andy Key
Version: 2.5 to PA
Excel Version: Lots
Re: Creating the Language Feed Files for Each TM1 Server
Post by Andy Key »
rinkugarg072 wrote:Hi All,
rootfeed_title_1
rootfeed_summary_1
Your own link wrote: 3. To configure the name that will appear in the content pane of the workspace, do the following:
For the rootfeed_title_1 property, replace the value with the name to appear in the content pane.
For the rootfeed_summary_1 property, replace the value with a description.
When you are in your Workspace accessing your data through the object hierarchy browser (which they are calling the content pane) you will see what you have entered as rootfeed_title as an element in the list along with the link to the main Cognos BI public folder and your TM1 Applications (nee Contributor) link if you have defined any. If you right click, or hover over the element you will then see what you have entered as rootfeed_summary.
Andy Key
