Cognos Insight 10.1 tutorial pdf
ioscat
OLAP Product: Contributor
Version: 9.5.2 10.1.1 10.2
Excel Version: 07+10+13
Post by ioscat »
Hello, forum!
Cognos Insight 10.1 tutorial is inaccessible in ibm.com. Does anybody have copy of this file?
I have 10.2 tut file, but our TM1 is 10.1, and i have no idea how to install insight 10.2 over cognos 10.1
this files can be freely downloaded directly from ibm, so i suppose my question is permissible
Edward Stuart
Version: All
Excel Version: All
Re: Cognos Insight 10.1 tutorial pdf
Post by Edward Stuart »
Cognos Insight details can be found here:
https://www-947.ibm.com/support/entry/m ... os_insight
Checking Insight 10.1 we can see that the tutorial links to a ZIP file on the analytics website:
http://www-01.ibm.com/support/docview.w ... wg27023298
This is not currently not available.
However, from the analyticszone website the tutorial may be available from their files section:
https://www.analyticszone.com/communiti ... 64d3c7f668
Note that Insight can be updated without affecting the current TM1 install.
ioscat
Post by ioscat »
analyticszone has only 10.2 tut file.
about updating insight - seems i misunderstood something in installing Cognos Insight, it says that it cannot be installed over other installation, and if i delete Cognos Insight (through Control Panel) there is no changes, it is still errorring. solved
