Is there any fucntion to get Adminhost name on which data server is running on.
I checked in IBM provided documents,but not found any info.
Example:
Adminhost Name: ABCTST
Data server name: XYzTST
Sathish
AdminHost Name
sathishh.mk
- Version: 9.4 and 9.5
Re: AdminHost Name
A TM1 server could be registered on multiple admin servers. You can get the list of admin hosts the server should be registered on from the adminhost parameter in tm1s.cfg
If you are talking about a function to return the physical machine name hosting the TM1 database instance I'm not aware of one (but well usually as a developer or administrator you should know what server you are running on!)
