Cognos Insight 10.2 capability question
Posted: Wed Dec 26, 2012 10:06 am
by bunchukokoy
Hi Good day!
I hope you don't mind, but I have another set of questions, I am new to Cognos Insight and I need to confirm if the ff are doable in Insight.
Just want to ask if the following scenarios are doable in Cognos Insight because I've tried but don't seem to get to it. Thanks very much.
1. If you're given a read-only access to only one cube in the TM1 server, will you still be able to at least connect to that TM1 server via Cognos Insight app?
2. If you have a read-only access to only one cube in the TM1 server, will you still be able to create a workspace/report that's sourcing from that one cube you're assigned with read-only access?
3. Can dimension alias attributes be used in Cognos Insight? I tried finding but can't see. Is it possible?
4. If I publish a Report 1.CDD file containing cubes A and B, can I still publish Report 2.CDD also containing at least one of these cubes? I tried but prompted with error.
5. If I delete any TM1 object in the Data pane in Cognos Insight, will it also be deleted from the TM1 server?
6. Can a user with read-only access to ALL cubes still be able to create his own CDD file using some of those cubes?
Thanks very much in advance.
