Selecting values ​​from the interval using IF
Posted: Sun Dec 23, 2012 8:40 am
by Antrac1t
I have some problems with select value from the interval through two cubes.
1, cube (Discounts) contains these dimensions: Intervals and Intervals metric (in context are Suppliers and Materials)
2, cube (Amount selection) contains these dimensions: Materials and Materials metric (in context are only Suppliers)
Now i want that when i will write some amount one material. Then I want obtain the price from a given interval, where the quantity is. This is a discount system.
For this problem i used this IF:
['price']=IF((DB('Discounts',!Intervals,!Suppliers,!Materials,'from')<['amount'])&(DB('Discounts',!Intervals,!Suppliers,!Materials,'to')<['amount'])<['amount']),DB('Discounts',!Intervals,!Suppliers,!Materials,'Price'),0);
(this rule is written in a cube "Amount selection")
Unfortunately it does not work but I think it should: D.
All this is done in the Performance modeler and Architect (10.1.1)
Thx for help guys.
Re: Selecting values ​​from the interval using IF
Posted: Mon Dec 24, 2012 1:00 am
by paulsimon
The problem is that your rule in Amount Selection is referring to dimension !Interval, but that does not exist in this cube. Your rule should also be written at the N: level.
If you only ever have 4 intervals then the following will work. If the number of intervals is variable then a more complex technique using recursion or using TI will be needed.
['price']=N:
  IF( ['amount'] < DB('Discounts','1',!Suppliers,!Materials,'To')
       DB('Discounts','1',!Suppliers,!Materials,'Price')
       IF( ['amount'] < DB('Discounts','2',!Suppliers,!Materials,'To')
            DB('Discounts','2',!Suppliers,!Materials,'Price')
            IF( ['amount'] < DB('Discounts','3',!Suppliers,!Materials,'To')
                 DB('Discounts','3',!Suppliers,!Materials,'Price')
                 DB('Discounts','4',!Suppliers,!Materials,'Price')
This rule is written using the Rule Editor rather than performance modeller.
Antrac1t wrote:Hello,
Thx for help guys.
Posted: Mon Dec 24, 2012 8:27 am
by Antrac1t
Thx for reply paulsimon, but its how you said ... i have intervals 1-n :( and in TM1 can not be used while ...
+ in amount selection i can write 1-n amounts
flour 150
water 50
salt 0
