Performance issue in Contributor
Posted: Wed Dec 19, 2012 3:17 pm
by nimol
I have a performance issue using tm1 contributor. When users are slicing and filtering one of the larger dimensions in contributor it takes considerable longer than if they do exactly the same using cube views in TM1 web.
The application is a simple one cube with 6 dimensions (account, time, version, organization, currency and code) where the largest is the approval hirarchy dimension (org.) with appr. 1,500 members and 4 levels of consolidation. Second largest is the account dimension with appr. 1,000 elements while the others dimensions are less than 50. No rules and feeders are applied.
Any advise?
