TM1 9.5.2 FP3 has been released
Posted: Sat Dec 15, 2012 11:16 pm
by moby91
http://www.ibm.com/support/docview.wss?uid=swg21620457
Cognos TM1 9.5.2 FP3 now available
News
Abstract
Cognos TM1 9.5.2 Fix Pack 3 is now available for download by supported customers.
http://www-01.ibm.com/support/docview.w ... wg24033957
http://www-01.ibm.com/support/docview.w ... wg27036833
IBM Cognos TM1 9.5.2 FP3 Release Notes
http://www-01.ibm.com/support/docview.w ... wg27036823
Cognos TM1 9.5.2 FP3 Fix List
TM1 9.5.2 FP3 for 32-bit Windows x86 is available for download on the IBM Fix Central website ->
http://www-933.ibm.com/support/fixcentr ... in32-FP003
9.5.2-BA-CTM1-Win32-FP003
Cognos TM1 9.5.2 Fix Pack 3 for 32-bit Windows x86
TM1 9.5.2 FP3 for 64-bit Windows x64 is available for download on the IBM Fix Central website ->
http://www-933.ibm.com/support/fixcentr ... in64-FP003
9.5.2-BA-CTM1-Win64-FP003
Cognos TM1 9.5.2 Fix Pack 3 for 64-bit Windows x64
Note:
Contact your local IBM Cognos TM1 Support when you need TM1 9.5.2 FP3 for the supported Unix platforms (Sun SPARC Solaris, IBM AIX) or Linux (RHEL).
Technical Documents specific to TM1 9.5.2 FP3
The following items describe known issues, new functionality, or documentation corrections specific to TM1 9.5.2 FP3:
(1)
http://www-01.ibm.com/support/docview.w ... wg27036900
Documentation Update: Websheet Export Limitations - Exporting TM1 Active Forms not supported in TM1 Web when Microsoft Excel is not on the web server
Product documentation
Abstract
TM1 Websheets that contain TM1 Active Forms cannot successfully export from TM1 Web as either a slice, snapshot, or PDF file when you run the IBM Cognos TM1 Web server on a web server that does not have Microsoft Excel. An "Operation Failed" error displays.
Content
The following limitations about exporting from IBM® Cognos® TM1® Web apply only when Microsoft Excel is not present on the TM1 Web server.
This condition applies when you set ExcelWebPublishEnabled=T in the tm1s.cfg file. For more details, see ExcelWebPublishEnabled parameter:
http://pic.dhe.ibm.com/infocenter/ctm1/ ... abled.html
Websheets with Active Forms
When Microsoft Excel is not present on the TM1 Web server, Websheets that contain TM1 Active Forms do not successfully export as either a slice, snapshot, or PDF file. An "Operation Failed" error displays.
Websheets without Active Forms
When Microsoft Excel is not present on the TM1 Web server, the following limitations apply to exporting Websheets that do not contain Active Forms.
Slice to Excel/Snapshot to Excel:
- OLE controls present in the Websheet are converted to images.
- Layout may be inconsistent between the Websheet and the resulting Excel worksheet/workbook.
- Headers and footers in the Worksheet are not exported.
- Form control states are not updated/displayed in the resulting worksheet
Export to PDF:
- Images present in the Websheet are not exported.
- Charts present in the Websheet are exported to a separate page in the resulting PDF file.
- OLE and form controls are not exported.
- Headers and footers are not exported.
(2)
http://www.ibm.com/support/docview.wss?uid=swg27036834
Using the DisableWritebackOnDisconnect Tm1p.ini parameter
Document Notes
Abstract
When enabled in Tm1p.ini, the DisableWritebackOnDisconnect parameter removes protection on worksheet cells containing TM1 worksheet formulas when there is no active connection to a TM1 server.
Resolution
When DisableWritebackOnDisconnect=T in Tm1p.ini, worksheet cells containing TM1 formulas that write to the TM1 server remain active and write to the server as long as an active server connection is available. However, when this parameter is enabled and the TM1 Perspectives client is not connected to a TM1 server, cells containing TM1 formulas that write to the server are no longer protected. In this case, entering a value in any worksheet cell containing a TM1 formula that writes to the TM1 server results in the TM1 formula being overwritten. TM1 formulas that write to the server include DBR, DBRW, DBRA, DBS, DBSA, DBSS, and DBSW. Setting DisableWritebackOnDisconnect=T also restores multiple level undo/redo and multiple copy/paste operations in a worksheet containing TM1 formulas when there is no active server connection.
DisableWritebackOnDisconnect has a similar effect as DisableWritebackOnTM1Formulas. The important distinction between these two parameters is that DisableWritebackOnDisconnect applies only when there is no active server connection, while DisableWritebackOnTM1Formulas applies at all times.
(3)
http://www.ibm.com/support/docview.wss?uid=swg27036835
Using the DisableWritebackOnTM1Formulas Tm1p.ini parameter
Document Notes
Abstract
When enabled in Tm1p.ini, the DisableWritebackOnTM1Formula parameter prevents writeback to the TM1 server when you enter a value in a cell containing a TM1 worksheet formula.
Resolution
When DisableWritebackOnTM1Formula=T in Tm1p.ini, entering a value in any worksheet cell containing a TM1 formula that writes to the TM1 server results in the TM1 formula being overwritten. TM1 formulas that write to the server include DBR, DBRW, DBRA, DBS, DBSA, DBSS, and DBSW. Setting DisableWritebackOnTM1Formula=T also restores multiple level undo/redo and multiple copy/paste operations in a worksheet containing TM1 formulas.
Re: TM1 9.5.2 FP3 has been released
Posted: Mon Jan 14, 2013 5:07 pm
by lpahnke
I'm curious if anyone has installed FP3 and if they have encountered any problems. We have installed it on our server, and in TM1 Web we can no longer enter data for numeric elements, for most of our input cubes. They are greyed out, as if there is a rule or security on them. All string elements work fine, and in one cube, some numeric elements also work. We have reported it to IBM, but don't yet know what is causing it, to determine if it's an issue with FP3, or something more specific to our installation. We have checked that it doesn't seem to be related to security, since it occurs for admin and non-admin users, and also only occurs in TM1 Web - when the same users log in to Architect, everything works fine. Has anyone else seen anything like this?
Posted: Mon Jan 14, 2013 5:32 pm
by whitej_d
I don't know if it's related, but there is an issue where old versions of the MSCOMCTL.OCX file don't work. It might be worth replacing the copy on the server install of Excel in case TM1web is using it?
http://www.tm1forum.com/viewtopic.php?f=18&t=8393
Posted: Mon Jan 14, 2013 7:59 pm
by Alan Kirk
Looks like it may need to be applied if you have Web:
Security Bulletin: IBM Cognos TM1 has cross-site scripting (XSS) vulnerabilities in the TM1 Web component (CVE-2012-6350)
Abstract
The IBM Cognos TM1 Web component contains a cross-site scripting vulnerability. IBM Cognos TM1 v 9.4, 9.5 and 10.1 are impacted.
REMEDIATION: Apply the appropriate fix pack or refresh pack to remediate these issues as per this table.
