Deleting damaged AttributeElement Cube
Gunnar
OLAP Product: TM1, MSAS
Version: TM1
Post by Gunnar »
Dear all,
I inherited a TM1 Environment from my predecessor.
The ElementAttributes Cube for the Dimension ITEM was somehow renamed to "ElementAttributes_ITEM_damaged".
However for month this Attribute Cube seemed to be ok anyway.
Now I tried to delete and re-structure some Alias Attributes for this dimension.
For some reason I can delete the alias attributes on N-Element level but cannot for C-Elements.
By the way, a cube named "... _damaged" doesn't make me feel very comfortable.
Therefore I would appriciate your thoughts regarding the following procedure:
In an test environment I was able to stop the TM1 Service and then to delete the CUB File for this attribute cube. Afterwards it was re-created automatically when I imported attribut values again. Would this procedure lead to problems?
Alternatively I thought about deleting and recreating just the attributes that cause problems. That might help, but I would need to stay with me "... _damaged" cube.
Is there any better idea?
Thanks for your input,
Gunnar
qml
Excel Version: 2007 - 2016
Re: Deleting damaged AttributeElement Cube
Post by qml »
Gunnar wrote:In an test environment I was able to stop the TM1 Service and then to delete the CUB File for this attribute cube. Afterwards it was re-created automatically when I imported attribut values again. Would this procedure lead to problems?
This is exactly what I would do, because this is the easiest and quickest way to do it. I can't think of any problems this would cause.
Kamil Arendt
garry cook
Version: Various
Excel Version: Various
Post by garry cook »
I'd agree however the possibly may exist that someone crazy enough to rule or TI reference a cube called x_damaged. Unlikely but given the fact the fact that it exists in the first place, I'd be wary of the whole model and double check personally.
Gunnar
Version: TM1
Post by Gunnar »
Thanks for your comments. I'm quite sure that the cube i want to delete is not connected to other cubes via rules.. So I think I will try delete and recreate the attributeElements Cube.
- Gunnar
