Hello esteemed TM1 programmers.
I see that TM1 Web has a URL API that I am guessing would let me create dashboards etc.
Not being a web programmer at all, my question is - how to get started?
What I would really be grateful for is an ultra-simple idiot's guide in a few lines that tells me what the basic mechanism is.
For instance if i were telling someone how to start VBA programming I would say.
1. Open Excel
2. Go Alt-F11 to enter the editor
3. Write some code
4. Save it as an add-in
5. Load the add-in
All help very much appreciated.
Ian
							How to get started TM1 Web programming
				iansdigby
- Version: 9 + 10 + Plan An
- Excel Version: All
						- Harvey
- Version: TM1 8.3 onwards
- Excel Version: 2003 onwards
Re: How to get started TM1 Web programming
The URL API in TM1Web is really just a way to open views and websheets with certain title element selections and parameters. You could create a dashboard (perhaps using iframes) this way, and it's pretty simple so long as you don't want to customize much.
Of course you'd need to learn html, but that's pretty basic and there are plenty of tools in existence to help you out.
If you want serious customization, you can use ASP.NET and the TM1 API, or other web technologies like PHP. If you're not a web programmer, you'd need to spend a lot of time learning, or just hire someone to help you out.
				rmackenzie
1. Open Notepadiansdigby wrote:I see that TM1 Web has a URL API that I am guessing would let me create dashboards etc.
2. Save a new file called test.html. This can be in My Documents or pretty much anywhere is fine.
3. Copy in this code
<html>
 <head>
  <title>Robin's Test Page</title>
 </head>
 <body>
  <iframe id="example_frame"
          name="example_frame"
          width=800
          height=800
          src="http://YOUR_SERVER_NAME/TM1Web/TM1WebMain.aspx?action=OpenObject&type=Cubeviewer&value=YOUR_CUBE_NAME$$YOUR_CUBE_VIEW">
  </iframe>
 </body>
</html>5. Save the file
6. From Windows Explorer, double-click to open the page
7. The page should open in Internet Explorer (or whatever your default browser is)
8. You'll probably get a small pop-up asking you to log-in to TM1
9. Now you're doing TM1 web programming!
More information:
TM1 URL API
HTML and other web stuff
Robin Mackenzie
				iansdigby
To rmackenzie,
Thank you profusely for this most helpful guide - at the risk of being boring, this is just what's lacking in the development world: basic training that gives a simple but satisfying result. Now I can get going and figure the rest out for myself!
Thanks again,
Ian
Thanks again,
Ian
