Attribute as Y/N flag in Allocation process
conflax
Version: Various
Excel Version: Various
Post by conflax »
I am building a TI process to perform a straightforward Allocation in a P&L cube. I need to be able to allocate Investment Income across different Scheme codes (Investment Income being an element in a dimension "Nominal", and "Scheme" being another dimension with 60+ elements).
By default my values go to one Scheme code and I am using an Attribute to define the allocation basis (GWP, Costs etc) and spread the income - this bit works fine.
What I want to be able to do is NOT allocate to certain Schemes. I have setup an Attribute "Alloc Investment Income" which is a Y/N flag against each Scheme Element and have tried to put in an IF statement to basically say :-
IF Attribute is Y
Do the allocation
Otherwise leave as is
However this does nothing. The TI runs successfully but no allocation is carried out. Playing with the values in the Y/N field does not appear to help. I have tried to remove any possible issue with consolidated elements by putting in the ELLEV in case that was the problem but no luck there.
Here is my TI code below. Hopefully I am just doing something stupid! Can you help please? Let me know if you need any more info.
Steve
s_CubeName='Reporting_Scheme';
s_DimName='Scheme';
s_AllocBasis = ATTRS('Nominal',Nominal,'Allocation Basis');
n_TotalValue=CellGetN(s_CubeName,Version,'All Acc Years','All Lines',Company,'All Cover Types','All Products','All Schemes',s_AllocBasis,v_Period,
v_Year);
n_Limit=DIMSIZ(s_DimName);
n_Counter=1;
WHILE(
n_Counter<=n_Limit);
s_ElementName=DIMNM(s_DimName,n_Counter);
IF(
ELLEV(s_DimName,s_ElementName)=0);
IF(ATTRS('Scheme',Scheme,'Alloc Investment Income')@='Y');
n_SchemeValue= CellGetN(s_CubeName,Version,'All Acc Years','All Lines',Company,'All Cover Types','All Products',s_ElementName,s_All
ocBasis,v_Period,v_Year);
n_Ratio=n_SchemeValue\n_TotalValue;
CellPutN(n_Ratio, 'Reporting_Scheme', Version,v_AccidentYear,LineOfBusiness,Company,v_CoverType,Product,s_ElementName,s_allocBasis|
'%',v_Period,v_Year);
n_AllocValue=n_Ratio*Value;
CellPutN(n_AllocValue, 'Reporting_Scheme', Version,v_AccidentYear,LineOfBusiness,Company,v_CoverType,Product,s_ElementName,Nominal,
v_Period,v_Year);
ENDIF;
ENDIF;
n_Counter=n_Counter+1;
END;
Re: Attribute as Y/N flag in Allocation process
Where is the variable Scheme defined????? Shouldn't this be:
IF(ATTRS('Scheme',s_ElementName,'Alloc Investment Income')@='Y');
conflax
Version: Various
Post by conflax »
(sound of flat hand hitting forehead)
Thanks very much tomok
I suspected it would be a schoolboy syntax error somewhere
Works fine now
