Has anyone connected to Greenplum through ODBC? I am going to try and get some data out of Greenplum and I would like to know where to get an ODBC connection . I am on TM110.1fp1 using Excel 2010.
Thank you
Greenplum
- qml
- Excel Version: 2007 - 2016
Re: Greenplum
I believe any PostgreSQL ODBC driver should work, but I have not tried this setup personally. Be sure to get the right version for your TM1 and OS (32 or 64 bit).
Kamil Arendt
- jim wood
- Version: PA 2.0.7
Re: Greenplum
This is a question for Green Plum. TM1 doesn't care about the ODBC connection type as long as the driver and connection exists on the server. It's the same as Oracle I'm guessing: install the odbc driver and then make a connection. Also keep in mind that TM1 doesn't care about the SQL used either. ODBC connections are all about the database,
Jim.
Jim.
