Hi All
I have a consolidation say A which has a elemnt b. "A" consolidation is used in a dimension many times as a child to different consolidation. I want now to delete b elemnt from "A"consolidation in just one parent rest all parent iwant elemnt b to be present in "A" consolidation.
I have tried using both delete and delete in consolidation. Both delete s the element from all the consolidation.
thanks
Dima
Deleting single element from consolidation
- Steve Rowe
Re: Deleting single element from consolidation
Thats to be expected. There is only one definition of the consolidation A, not a different one depending on what it rolls into.
You either need a different A underneath each conso where its different, or put your element B with a weighting of -1 above the conso A in the hierarchies where you want b removed.
Second option sounds better.
i.e.
Conso C = A -b
Conso D = A
So you leave your definition of A alone.
i.e.
Conso C = A -b
Conso D = A
dima55
- OLAP Product: tm1
- Version: 9.5
Hi Steve
Thanks alot.It works all fine
Dima
Dima
