N_Disconnect Crashes when Rules are open
Posted: Tue Oct 23, 2012 12:45 pm
Hi all
is there a way to check to see if the Rules editor is open and to close the rules editor first before using the command N_Disconnect in a macro?
currently the N_Disconnect works perfectly if its just cubes open and will close them down and log off the servers, however if i have a rule editor open at the same time it causes my Tm1 to hang and i need to crash out.
thanks all
thanks all
