Is there a way to restrict users using TM1 Perspective to connect to the TM1 server from their machines.
Naresh.
Restricting Perspective
Re: Restricting Perspective
Sure.
Remove their credentials from TM1.
Andy Key
- Version: 2.5 to PA
- Excel Version: Lots
If by TM1 Perspectives you mean the Server Explorer interface, then have a look at the RunServerExplorer element within Capabilies.
Andy Key
naresh223
- Version: 9.4
- Excel Version: 2003
David--I would agree with you removing the credentials from TM1 server but this will also remove the access to the Cognos BI reports that are using the TM1 cubes. This scenario will not be helpful in this case.
Andy-- Thanks very much to you. As you suggested RunServerExplorer has resolved my problem. Now users are not able to see the server from TM1 Perspective.
Naresh.
Naresh.
