PMPSVC - The planning service parameter was not specified
Posted: Fri Oct 12, 2012 2:01 pm
by ioscat
we got the error while trying to connect to PMPSVC
The planning service parameter was not specified or is not one of the configured locations
made all advices by ibm :
http://www-01.ibm.com/support/docview.w ... wg21502002
but still no effect
all work is on the virtualmachine
this copy works on another pc
Re: PMPSVC - The planning service parameter was not specifie
Posted: Wed Jan 15, 2014 8:26 am
by ioscat
Hello once again.
I have configured my system, it seems to OK but not enough.
All configuration files are set to
http://testpc... (not testpc.localdomain)
If I go to
http://testpc/ibmcognos - I can see my applications
When I try to go to
http://testpc:9510/pmpsvc it redirects me to
Here parameter
ps (at the end) is "testpc.localdomain" -
but where is it stored?
This redirection shows error "The planning service parameter was not specified..."
If I change manually this part of the link from "testpc.localdomain" to "testpc" - I got the correct page with my application portal.
Files planning.html and ...config.xml are already checked.
Re: PMPSVC - The planning service parameter was not specified
Posted: Fri Nov 13, 2015 7:54 pm
by Kingsley
The actual machine name used in the URL is defined in External Server URI in TM1 Application Server section of Cognos Configuration.
Posted: Mon Nov 16, 2015 3:35 pm
by LutherPaul
That should be specified in fpmpsvc_config.xml located under \tm1_64\webapps\pmpsvc\WEB-INF\configuration.
check this parameter.
<external uri=
