Hi there, searched around but couldnt find any thing specific.
My TI runs an execute command for a batch, the batch file runs correctly if I manually run it. But TI does not run the process
the batch calls a vb script eg. C:\windows\system32\Cscript.exe E:\TM1_... ###.vbs
If I put a file create eg. dir > E:\TM1_...dir.txt it creates the file so the settings in the executecommand are pointing correctly.
Is there a setting in the batch file I would need to make so it can call a vbs?
thanks in advance.
executecommand doesnt run a batch
- Version: 9.5
Re: executecommand doesnt run a batch
I have tried running vbs file from a batch file using the TI execute command and it works.
Have you check if permission is given to the vbs file ?
did you try running other vbs script to see if it works ? Below is a sample script to create a directory and file which works when i run it.
Option Explicit
Dim objFSO, objFSOText, objFolder, objFile
Dim strDirectory, strFile
strDirectory = "c:\tempx"
strFile = "\Summer.txt"
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objFolder = objFSO.CreateFolder(strDirectory)
Set objFile = objFSO.CreateTextFile(strDirectory & strFile)
Wscript.Echo "Just created " & strDirectory & strFile
Wscript.Quit
- Andy
- Version: 2.05
Hi BigG,
does your batch needs any parameters?
Can you show us your TI script?
In my opnion it should not be a problem to run batch files from a TI process.
I just did it a few weeks ago.
By the way:
Which TM1 version do you use?
By the way:
- Version: 9.4.1 - 10.1
Depending on your OS and the nature of your vbs script, you might be encountering the problem I ran into here - http://www.tm1forum.com/viewtopic.php?p=33913#p34024.
- OLAP Product: IBMPA
- Version: PA 2.0 Cloud
thanks for the replies, answers to questions:
It seems we are onto something with
viewtopic.php?p=33913#p34024. as it is also calling xml excel create vbs
creating C:\Windows\SysWOW64\config\systemprofile\Desktop folder
and it works!!!
and it works!!!
GG
