ATTRS/N or DB}ElementAttributes for rule?
tosca1978
Version: 9.5.2
Post by tosca1978 »
I was just wondering what the best practice is for referencing an attribute from within a rule. For example I could write the following 2 pieces of code within a rule to achieve the same result:
ATTRS('Time_Day',!Time_Day,'Act For')@='Actual',
or
DB('}ElementAttributes_Time_Day',!Time_Day,'Act For')@='Actual',
But I was wondering if either one performed better than the other or if there was a good reason to use one over the other. In worksheets I tend to use the DBRW approach into the }ElementAttributes cube rather than a DBRA formula if I'm copying the formula down a lot of rows becuase I think this performs better.
Re: ATTRS/N or DB}ElementAttributes for rule?
tosca1978 wrote: I was just wondering what the best practice is for referencing an attribute from within a rule. For example I could write the following 2 pieces of code within a rule to achieve the same result:
or
Interesting question. I recall Andy Key stating that he had been told that a DBR worksheet function is faster than a DBRA, but whether the same is true of rules functions I couldn't say; it would be interesting to know if his informant provided some details on that. (Whether the difference would be material is another matter.)
ioscat
OLAP Product: Contributor
Version: 9.5.2 10.1.1 10.2
Excel Version: 07+10+13
Post by ioscat »
don't really know if it is a good test:
1) created dim2 with 10^x elements
vCount = 1;
vDimSize = 100000;
WHILE (vCount<vDimSize);
vCount_s = str(vCount, 10, 0);
dimensionelementinsert('dim2','', vCount_s,'n');
attrputs(vCount_s, 'dim2', vCount_s, 'test');
vCount = vCount + 1;
END;
cube1 rule
skipcheck;
['a'] = N: NUMBR(ATTRS('dim2',!dim2,'test'))
+NUMBR(ATTRS('dim2',!dim2,'test'))
+NUMBR(ATTRS('dim2',!dim2,'test'));
cube2 -
skipcheck;
['a']=N:NUMBR(DB('}ElementAttributes_dim2',!dim2,'test'))
+NUMBR(DB('}ElementAttributes_dim2',!dim2,'test'))
+NUMBR(DB('}ElementAttributes_dim2',!dim2,'test'));
didn't get any difference
Andy Key
Version: 2.5 to PA
Excel Version: Lots
Post by Andy Key »
Alan Kirk wrote:Interesting question. I recall Andy Key stating that he had been told that a DBR worksheet function is faster than a DBRA, but whether the same is true of rules functions I couldn't say; it would be interesting to know if his informant provided some details on that. (Whether the difference would be material is another matter.)
Unfortunately not. We were only talking about worksheet functions.
Andy Key
