Exclude rule-based measures in Drill Assigment Rule
Posted: Tue Oct 09, 2012 5:25 am
by bunchukokoy
Hi Guys,
I have an existing Drill Assignment Rules in which Drill Rules are indicated for each measure I put in that rules.
Here's the sample.
['line void amount']=S:IF((dimix('report month',subst(!period,1,3))<=12 % subst(!period,3,1)@='/') & ellev('period',!period)<=1 & ellev('site',!site)<=2 & ellev('ebr_employees',!ebr_employees)<=1,'ebr','');
['line void count']=S:IF((dimix('report month',subst(!period,1,3))<=12 % subst(!period,3,1)@='/') & ellev('period',!period)<=1 & ellev('site',!site)<=2 & ellev('ebr_employees',!ebr_employees)<=1,'ebr','');
['void txn amount']=S:IF((dimix('report month',subst(!period,1,3))<=12 % subst(!period,3,1)@='/') & ellev('period',!period)<=1 & ellev('site',!site)<=2 & ellev('ebr_employees',!ebr_employees)<=1,'ebr','');
As you can see, the rules for each measure are all the same. I actually have 20 more measures for this rule.
What I want to happen is to have just one line for all of those measures. But my measure dimension also contains rule-based measures that I want to exclude in drill troufh function.
I am imagining, I can just put
[]=S:IF((dimix('report month',subst(!period,1,3))<=12 % subst(!period,3,1)@='/') & ellev('period',!period)<=1 & ellev('site',!site)<=2 & ellev('ebr_employees',!ebr_employees)<=1,'ebr','');
But this rule will work for rule-based measures. CellIsupdatable can be used but if I do, this will exclude consolidated elements for TI-uploaded measures.
Is there other solution for this?
Thanks in advance.
Bunch
Re: Exclude rule-based measures in Drill Assigment Rule
Posted: Tue Oct 09, 2012 7:07 am
by Wim Gielis
Hi Bunch
The easiest would be to use [] while you insert an IF test to look at a particular attribute: to know if you want to drill or not.
So use a Text attribute (for example, "Drill-through measure") using Y/N and the Attrs function will read that value Y/N.
I imagine this list of drillable measures to be quite static so a Text attribute will be fine.
Posted: Tue Oct 09, 2012 7:12 am
by bunchukokoy
Yes Sir,
I have thought of this one. Although with this, the text attribute should be maintained if ever new measures will be added. But yes this one is the best solution I guess.
Thank you Sir Wim.
Bunch
Posted: Tue Oct 09, 2012 7:55 am
by Wim Gielis
bunchukokoy wrote:Yes Sir,
Thank you Sir Wim.
Bunch
You could present an Excel spreadsheet or Websheet to update the attribute.
Don't think that maintaining drill rules will be as easy... ;-)
