RAM Capacity to Load TM1 through CITRIX
Posted: Wed Sep 26, 2012 10:02 am
by pradeep.k.jagadeesan
I am connecting to a remote server through CITRIX and accessing TM1 server. But it is very slow. I believe that CITRIX is using local Workstation's RAM and TM1 objects also using local workstation RAM, please correct me if i am wrong.
In the remote server we have TM1 10.1.1 with full installation. But TM1 is not installed in my Work station.
My workstation configuration:
RAM capacity is 3GB.
Processor Intel Core i5 @2.50Ghz
Operating System Windows XP
If i need to upgrade my workstation's RAM capacity, then what is the size?
Thanks in advance.
Pradeep
Re: RAM Capacity to Load TM1 through CITRIX
Posted: Wed Sep 26, 2012 10:26 am
by Paul Segal
1. Have you tried accessing another application via Citrix? Say, Excel without TM1 loaded. If so, is that slow?
2. If everything is slow, then you probably have a Citrix and/or bandwidth problem.
3. If only TM1 is slow, then you have a TM1 problem. What's the speed like if you are on the local LAN? Can you test this?
Posted: Wed Sep 26, 2012 11:33 am
The most obvious question is what's the proximity and latency on the LAN/WAN of the Citrix server to the TM1 server?
Posted: Wed Sep 26, 2012 12:52 pm
by tushar.marathe
I would suggest getting in touch with CITRIX Administrator responsible for the CITRIX server. He should be able to identify the root-cause and allocate more memory share/block for TM1.
