I am setting up the new TM1 10.1 server. I have problem in configuring the TM1 Operations console with the TM1 server which is using the security from Cognos BI. I am able to successfully configure it with TM1 samples but not with the company server which is using security from cognos BI. While I try to login with the proper credentials it is throwing "An error occured while validating the credentials". Can someone help me to get out of this.
Regards.
Issue with TM1 10.1 Operations console
- OLAP Product: tm1
- Version: 10.2
- Excel Version: 2013
Re: Issue with TM1 10.1 Operations console
Operations console doesn't support BI security
http://www-01.ibm.com/support/docview.w ... wg27023757
But there is a work around;
I did found a work around, I installed another tm1 server next tot it (go_new_stores or plansamp), with native tm1 security. Now I can log in via this server with native security, and then select the other server(s). The only thing I cannot do is kill processes or disconnect users, but that's a known defect with cognos security.
- Version: 9.4
- Excel Version: 2003
Hi Sader,
Thanks for the update. First I have tried with the one you have suggested, I was able to see the company servers and not Kill the processes, thought I was doing mistake. Later I tried configuring the company server first and it din't allowed me login throwing "An error occured while validating the credentials". I thought I have done mistake somewhere. Know came to know its a known cognos defect. Thanks for clarifying me.
