TM1 attribute values not showing up in drop down for filter
jcblough
Post by jcblough »
I have a dimension with several attributes that the user would like to filter on. They are populated properly and when I filter on an attribute, they are available for selection. Trouble is when I go to select which value I want, that drop down is empty. What could cause this?
To clarify, they don't show up when filtering on the cube, I can use them just fine to create subsets.
Re: TM1 attribute values not showing up in drop down for fil
Post by David Usherwood »
Your current selection of elements probably doesn't include any where the attribute is the one you want. Try it again after resetting to 'All'.
jcblough
Post by jcblough »
that'll do it - thanks man!
