Greetings fellow TM1 developers,
I'm totally new with the latest 10.1 version of TM1 and Express Planner. In 9.5 it was pretty easy to set cubes to automatic recalculation in Architect. In this new version I have set all cubes to automatic recalc mode in Architect but it just won't work in the Application Web. This sounds like it would be pretty easy to find it in the new Modeler intuitively or that it would be in Contributor but no. I haven't found this feature but only in Architect and it doesn't work. Does this feature lack in Express Planner 10.1 or am I just missing something?
Thanks in advance for replies!
Also I cannot execute Process Generated Links. I get CAMID error, a line in Prolog that looks really harmless. I migrated applications from 9.5 to 10.1 and I guess it has something to do with this. Anyone else experiencing this problem and is it solvable? Google, unfortunately has so few answers on these topics.
Automatic recalculation with Express Planner 10.1
olapc
- OLAP Product: Planning, TM1
- Version: 9.5.1
Re: Automatic recalculation with Express Planner 10.1
Short simple answer is enough. Where do I apply automatic recalculation to cubes. I suspect there could be something wrong in the installation.
Thank you!
Thank you!
You don't set a cube to recalculate automatically. You set a view. The Default view is the view you open if you have not specified a named view. Set at to automatic calc and save.
olapc
- Version: 9.5.1
That must have been the only place I havent looked.
Many thanks to you.
Many thanks to you.
