Consolidation levels
Hello there
Just an oddity I encountered (TM1 v9.5.2 if that matters).
Create a consolidated element ("ABC").
Add a different consolidated element (XYZ") to "ABC" (as a child).
Do not add an n-type element to "XYZ".
Open up the Subset editor for this dimension, show the Properties pane, and click on "ABC".
Then we see that "XYZ" is level 1 in the dimension.
Do the same in the Dimension Editor and you will see that XYZ is level 0 in the dimension...
Strange?! Can anyone shed light on this?
Wim
