Hello ALL,
We had one web-sheet which was opened in TM1 in 20 secs, and now after adding one more column, it started taking around 2 mins of time. So not sure, what could be the possible reasons. we are on TM1 9.5.2 FP2. We saved the file in 97-2003 version in excel as it was and the after making changes, we updated it.
Any suggestion!!!!
Manoj
Web-sheet loading time drastically increased
- George Regateiro
- Version: 10.1.1
- Excel Version: 2007 SP3
Re: Web-sheet loading time drastically increased
Did this new column exceed the bounds of your view (or RPTVIEW if an active form) statement? If you are requesting items out of this range then you can easily bloat load and calc times .
