Integrating TM1 with Xcelsius
Posted: Wed Sep 12, 2012 3:39 pm
by MKusuma
I've been trying to google my topic and search it here but could not find the Xcelsius - TM1 integration topic.
Can anyone recommend and explain the best way to integrate TM1 with Xcelsius?
Thanks in advance for your help!
Re: Integrating TM1 with Xcelsius
Posted: Thu Sep 13, 2012 12:25 am
by Solanna
Given that Xcelsius is an SAP/Business Objects product (a bit outdated as well) I highly expect there isn't any connectivity between it and TM1
If memory serves I believe you can use an Excel spreadsheet or a CSV file as your data source so you could certainly either take a snapshot of your TM1 cube view or export the cube data into a flat file
Other than that maybe you should have a look at the IBM Cognos product portfolio for a more compatible solution
Posted: Thu Sep 13, 2012 2:02 am
by Martin Ryan
Olap Objects does (or at least did) offer some connectivity between the two. Visit olapobjects.com, or PM our own Mike Cowie for more details. We use Olap Objects and have found it pretty good though have not had cause to use the Xcelsius integration.
Martin
