TM1 Drill Through works in Architect but not Contributor
adaptive_tech
Version: 9.5
Post by adaptive_tech »
Greetings all
I've created a Drill Through process in Architect, and it works just dandy. I can drill all over the place.
I've re-Deployed the TM1 Contributor application, but I can't drill anywhere. The "Drill" option is just greyed out when you right-click.
Has anyone else experienced this problem?
Re: TM1 Drill Through works in Architect but not Contributor
What user ID are you logged into in Architect vs. Contributor?
Don't forget that for drills to work for non-admin users you need to grant read access to the relevant }Drill process.
adaptive_tech
Version: 9.5
Wow, worked like a charm! Thanks so much!
I wish they were explicit about that in the instructions. :\ They seem to assume that you'll know to change the Security assignment on these hidden Control Objects. At least you can do it easily by adding a Rule to the }ProcessSecurity Cube.
