Has any one face the issue of the changes of the rules is not pick up when changes is made directly to the RUX file ?
I have change the rules in the RUX file and restart the service but yet when i went to architect to have a look at the rules, the new rules is not there.
Applying Rules
- qml
- Excel Version: 2007 - 2016
Re: Applying Rules
From the IBM Cognos TM1 Rules Guide:
When you create a rule, TM1 also generates a file called cube_name.blb, which contains format information for the Rules Editor.
If you want to edit a .rux file in another text editor, you should delete the corresponding .blb file. If you do not delete the file, there will be a discrepancy between the contents of the .rux file and the display in the Rules Editor, as the display of the Rules Editor is determined by the .blb file.
Kamil Arendt
